QNA-UC10G2T
        USB 4 Type-C to Dual-Port 10GBASE-T RJ45 Network Adapter, Compatible with USB 4 and Thunderbolt™ 3/4 Ports
                                Enjoy stable 10GbE high-speed networking using a USB Type-C connection to greatly enhance work efficiency, even on computers without built-in network ports.
Dual 10GbE Ports
Expand a single Type-C port into two 10GbE ports, delivering exceptional stability and flexible network configurations.
Broad interface compatibility
The QNA-UC10G2T includes a 1-meter USB 4 cable for connecting to your computer's USB 4 or Thunderbolt™ 3/4 ports.
● Windows: Compatible with USB 4 and Thunderbolt™ 4 ports.
● macOS: Compatible with Thunderbolt™ 4 and Thunderbolt™ 3 ports.Multi-system compatibility
Supports Windows®, macOS®, and Linux® computers (driver installation required).
Not compatible with Windows® OS running on ARM-based processors.
Multi-speed support
Compatible with various network environments through Multi-Gigabit support for 10/5/2.5/1 GbE.
No Fan, No Noise
Fanless design ensures stable performance with reduced noise and maintenance, offering a quiet, reliable experience for long-term use.
Stylish metal finish and portable
Perfectly fits in with all your tech gear
        Secure, Stable, and Efficient with Dual 10GbE
Enjoy network upgrades anywhere with doubled efficiency
Build a high-speed network environment with a 10GbE switch
In multi-user, multi-device environments, connect your computer to a QNAP 10GbE switch using the QNA-UC10G2T network adapter to create a high-bandwidth, high-speed collaborative network across multiple connected devices.
Explore enterprise high-speed networking solutions >
        How to set the MTU
Note: When connecting to a network switch, please ensure the Jumbo Frame on the port is also set to 9000 (MTU size).
MacOS:
1. Open System Settings and go to Network.
2. Select QNA Thunderbolt Ethernet and click Details.
3. Go to Hardware, change Configure to Manually, and set MTU to  Jumbo (9,000).
Windows:
1. Open Settings and go to Network & Internet.
2. Click Change your adapter options, right click the QNA adapter and click Properties.
3. Click Configure, go to the Advanced tab, select Jumbo Frame and set the value to 9KB MTU.
NAS:
1. Open Network & Virtual Switch
2. Go to Interfaces and find the Ethernet adapter on the Adapter List.
3. Open the adapter menu and select Configure.
4. Go to the IPv4 tab and set Jumbo Frame to 9000.
Need help?
